365
misaligned column headers and footers
Hello All,
We're using a NetAdvantage for .NET 2009.1 UltraWebGrid that was previously looking fine.  I've since moved it to use a bound dataset (before it was populated row by row and cell by cell).  Now the column header and footer widths are not aligned with the data column widths.  The first column header is narrower, which propagates to all the columns after.  If I widen the 1st column header, then all columns align properly.
The grid currently has UseFixedHeaders and StationaryMargins set, which were original settings.  Can someone advise how I can get the header and footer to be aligned again with the data rows?
It's been suggested in a related post to make sure the page DOCTYPE is XHTML.  So I manually add the DOCTYPE line to the HTML or is there another way to do it in VS?  All worked before when it didn't use a bound dataset, so maybe that's not the case here.
Thanks for any help.
Corey.
