310
Edit Mode Format
I have a column with the format string set to currency. When the cell goes into edit mode it shows a total of 4 decimal places instead of 2. What is the easiest way to format the value in edit mode so that it will show only 2 decimal places? Thanks.
  • 40030
    Verified Answer
    So the easiest way is to apply a ValueConverter to the EditorValueConverter of the Column:
     public class MyEVC : IValueConverter
            public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                return String.Format(culture,"{0:c}", value);
            public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                return value;
      <ig:XamGrid.Columns>
                   <ig:TextColumn Key="ChapterNumber" FormatString="{}{0:c}" EditorValueConverter="{StaticResource evc}"/>
                </ig:XamGrid.Columns>
    Hope this helps,
    -SteveZ
