I am using Infragistics 10.2 WebHTMLEditor and the text is overflowing the bottom of the control instead of causing scrolling in IE7 or in IE8 when run in IE7 compatibility mode.
Check the work around for this - http://narsimlusblog.blogspot.com/2011/01/overflow-issue-in-infragistics.html
Narsimlu
Upgrading the the latest service release ASP.NET 10.2.201002.2152 fixed the issue.
I'm still having the text overflow issue mentioned in this post using I believe the latest service release, released in Nov 2010.
Is there any update on this?
Version info:
Infragistics35.WebUI.WebHtmlEditor.v10.2Version=10.2.20102.2101Culture=neutralPublicKeyToken=7dd5c3163f2cd0cb
Thanks for any advice.
Hello Gary,This is a development issue which is already fixed and currently is in test mode. I believe that will be included in to the next service release in the middle of the next month. More information about the planed dates of the service release you can find here:http://ko.infragistics.com/support/documentation.aspx#ServiceReleases
Regards
Sorry .. forgot to add that I am using 10.3, despite my signature (which I just updated!).
Gary
