425
Row selection
I want the ability to select a entire row on clicking a cell in the row.  In the grid, i have the following selection settings:
                <igGrid:XamWebGrid.SelectionSettings>
                    <igGrid:SelectionSettings CellSelection="None" CellClickAction="SelectRow"
                        ColumnSelection="None" RowSelection="Single"/>
                </igGrid:XamWebGrid.SelectionSettings>
Even with the above settings, the mouse click select a cell than a row. I am modifying an existing code. So, i am afraid there are other grid attributes that are suppressing my above code behavior in the grid.
Are there any other properties in XamGrid that could override these attributes?
  • 6475
    Verified Answer
    Your settings look fine. You shouldn't be able to select a Cell with the given SelectionSettings. And since you turned the RowSelection on, and have set the CellClickAction to "SelectRow", mouse click should always select a Row.
     Are you sure you aren't modifying the SelectionSettings in code-behind (e.g., on UserControl's Loaded event or somewhere else) ?
