I can change the language of windows filter or any windows / tooltip ?
The properyt Language of the xamGrid is ignored ! Why ?
Hello AMUS,
Please refer to the following sample's XAML code (click on the < /> tab to the right).
http://labs.infragistics.com/silverlight/lobsamples/2010.3/#/Samples/Grid/KeyFeature/GridFormattingRowSummaries
Setting the display text can be done in XAML (which I find easier) like this:
<ig:SummaryColumnSettings> <ig:SummaryColumnSettings.SummaryOperands> <ig:MaximumSummaryOperand FormatString="{}{0:d}" /> <ig:MinimumSummaryOperand FormatString="{}{0:d}" /> <ig:CountSummaryOperand RowDisplayLabel="Alternate COUNT Text" SelectionDisplayLabel="Alternate COUNT Text" /> </ig:SummaryColumnSettings.SummaryOperands> </ig:SummaryColumnSettings>
To do it in VB, please refer to this topic in the online help. Instead of setting IsApplied, you would set RowDisplayLabel and SelectionDisplayLabel.
Imports Infragistics.Controls.Grids
Imports
Dim DisplaySummary As Column = Me.MyDataGrid.Columns.
Dim
As
Me
DataColumns("ProductName")
"ProductName"
DisplaySummary.SummaryColumnSettings.SummaryOperands(2).
RowDisplayLabel = "Alternate COUNT Text"
SelectionDisplayLabel = "Alternate COUNT Text"
You can also set the filter operand text this way on the xamGrid.FilteringSettings object.
As for the resource files, they would be in English. You can download them with our source code from "My Keys and Downloads" with your Infragistics account (go to infragistics.com > My IG > My Keys and Downloads). I'm not sure if it's available as a trial customer. In general, you could copy the resource file, rename it to [Name].it.resx, and then translate it. Rebuilding the assembly should create a version of the control which uses English by default, and Italian when running on an Italian operating system.
Let me know if this is helpful.
Elizabeth AlbertLocalization Engineer
Did you can the example in VB.NET for use the API for change the words "average" for the sum columns or "equal" to the filters for example.
Thank you
Did you can the example for use the API for change the words "average" for the sum columns or "equal" to the filters for example.
How I can download the .resx (resource) for italian language ?
I have the trial version.
Thank's
What language are you looking for? We currently have localized our product to Japanese (complete) and German (end user strings only). We have a separate installer for Japanese, which will include satellite assemblies providing localized controls. The German satellite assemblies are included in our English installer. The German translations should appear if you are running the application on a German operating system.
In my experience, only WPF controls need to have the Language property of the application or control changed. This shouldn't be the case in Silverlight.
For other languages, you have 2 options.
1. You can download our source code from "My Keys and Downloads" on the main web site. You'd be looking for .resx (resource) files for the control you would like to localize. You can rebuild that assembly's project and use your localized version of our assembly. This would be the easier way if you plan to localize many parts of the control.
2. You can view the APIs and override the default English strings in the code behind.
If you have questions on how to do this, please ask.
Elizabeth Albert
