610
Bug When Using Themes
Hello, I ran into a small bug but it's causing my application to crash.
I'm not sure if this is a bug in the tree or the outlookbar, but when you have the themes enabled, and you have some sort of custom header setup in the tree items, then it crashes the application if you move from the Group1 to Group 2 back to Group1 on the Outlook bar.
I'm not sure if there is a work around that I could use or if this is a bug.
Tree Error.zip
