WebChart does not help the reaction.XamPivotDataSelector row with multiple columns is inserted inWebChart is not working properly.Why did they do it?Cells in the process of merging with the values that could not read the chart mean?Byeonhaejin does not recognize the value chart is not working.chart control's row and columns to work Is there a limit?
The chart works
Do not have a chart to work
It looks like you have been talking to Todor here: https://ko.infragistics.com/community/forums/f/retired-products-and-controls/48288/pivot-grid-and-chart-does-not-work-like-that
Has he helped you with this problem?
-Graham
Do you think you could provide a sample project that illustrates the problem and explain what you expect the behavior to be? Its a bit difficult to tell from your explaination what problem you are having.
