I'm trying to perform groupby on a xamgrid. I'm using the virtual collection to load the data. I have one million rows on the server side and I'm loading 1000 rows at a time. I'm also making use of deffered scrolling. I have used
<ig:XamGrid.GroupBySettings> <ig:GroupBySettings AllowGroupByArea="Top" /> </ig:XamGrid.GroupBySettings>
in my .xaml file.
Some how the groupby doesnt take place. It just hangs the entire application. I tried with smaller data it works fine. Am I missing something?
Sayali
Is there a workaround to do this? We are planning to buy the controls but we need grouping to be supported along with scrolling or atleast a workaround to do it. It's urgent please do reply.
Is there a chance of this being supported in the future versions? Because we don't want to use paging. We need to use only deffered scrolling/real time scrolling.
Using VC in non-paging mode together with Grouping is not supported.
You should probably look into the paging capabilities of the XamGrid / VirtualCollection.
HTH,
I'm having the same problem with summarysettings as well. Through some more investigation I realised that the entire collection is getting loaded for these two setting. Is this true? But I do not want to load entire data on the client side. Is there any workaround for this. This is an urgent issue. Please do reply.
