600
XamComboEditor focus problem
HI
Over a MVVM model, I have a form with three controls: two XamComboEditor (version 10.3.20103.1006) and a TextBox. The second XamComboEditor IsEnabled property depends on the contents of the first: IsEnabled = "{Binding Path = HabilitarEstilo}".
When the user changes the selected item from the first XamComboEditor and this activates the second XamComboEditor (IsEnabled = True), and then try to move the focus to the second XamComboEditor (using [Tab] key or the mouse) immediately focus jumps into the following TextBox.
No control has code in events (everything is MVVM) and using "Silverlight Spy" I see two XamComboEditor always pass the IsTabStop property to false, so you enter to True.
Please, could you help me with this problem?
Thank you,
Jaimir G.
