Hi experts:
I am using the trial version to evaluate the xamlPivotGrid, I used the sample to connect my owned cube (SSAS 2005), I can see the Databases, Cubes and Dimensions. But when I drag the measure into the data area, the value is not shown. It can work if I connected it to http://sampledata.infragistics.com/olap/msmdpump.dll.
I also used Excel to connect my owned cube, it's not problem. Could you please give me some hints to fix it? Thanks.
Thanks.
It works now, thanks a lot.
I have created support case (CAS-58831-SYJ78F) for you and will send you in private the link of the latest service release.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
How to get the latest version? I downloaded the trial version again but it still cannot work.
Do you use the latest version of pivot grid. We had Service Release on 16 Dec 2010. The bug is fixed in this SR
Regards
Todor
