Is Infragistics2.WebUI.UltraWebGrid.v6.3 (6.3.20063.53 ) fully compatible with IE8?
I'm getting an Error: 'style.cssText' is null or not an object on Line: 1504 of /scripts/ig_WebGrid_cb.js.
Thanks for given your alternate solutions. But we can't upgrade our infragistics version just for this one single Javascript error. Because we installed in client place and working everything other then this issue in IE 8. Is there any other solution to fix in V6.3 version?
Thanks.
I did a lookup on the Supported Environments and it shows that 6.3 was not supported in IE8.
The full statement is: Internet Explorer 8.x => NetAdvantage for .NET 2009 Volume 1 (service release required), or NetAdvantage for .NET 2009 Volume 2 and later. On Windows only.
The Supported Environments can be found here: http://ko.infragistics.com/support/product-lifecycle.aspx#SupportedEnvironments.
