600
Problem binding Axis Range Properties
Hi
Our app is SL 4 and MVVM design pattern, it was using the XamWebChart version 10.1, we made bindings for axis’s ranges parameters:
<igWebChart:Axis AxisType="PrimaryX" AutoRange="False"
   Minimum="{Binding Path=ValorMinimoX, Mode=OneWay}"
   Maximum="{Binding Path=ValorMaximoX, Mode=OneWay}"
   Unit="{Binding Path=DivisionEscalaX, Mode=OneWay}"/>
We update to version 10.3.20103.1006, and it stopped working correctly, now constantly displays the message:
XamWebChart Warning: If the AutoRange is set to false, Maximum must be greater than Minimum and Unit value must be greater than zero.
The values of properties are: ValorMinimoX=0; ValorMaximoX=100; DivisionEscalaX=10;
PropertyChange event doesn’t update the bindings.
Could you help to find the cause of the problem?
Thank you
Jaimir G.
