Hi
I have a question about the Calendar control. Is there way to hightlight the date inside of the DateChooser when it gets focus. The problem is, then I set a focust for the control cursor gets set to the first position of the control's text box and user to change a date has to delete the date and after that type in the correct one. When date inside of text box is highlighted used does not need to delete the date, he/she just starts typeing the correct date e.g. user can overrides the current date without erasing it. The setting for the control set to not allow null, by default it shows today.
Vladimir
Hello vvorobiev
Let me know if you need further assistance with this.
Lyuba
Developer Support Engineer
www.infragistics.com/support
Hello vvorobiev,
This is the default behavior of the webdatechooser – when it gets the focus, the whole date inside it gets selected. I have attached a sample application that shows this behavior. If for some reason this is not happening at your end, would you attach a sample that illustrates your issue.
