We have recently upgraded to 2010.2. I want to use the UltraGridExcelExporter - which seems not to be part of this release, and the WebExcelExporter only supports WebDataGrid and WebHiearchalGrid.
I want to keep the UltraWebGrid and I also want to have export to excel feature.
Any help will be much appreciated.
Thanks it works.
The assemblies still exist and you can add them to your toolbox (take a peek at C:\Program Files (x86)\Infragistics\NetAdvantage 2010.2\ASP.NET\CLR3.5\Bin or wherever you chose to install the product). It is no longer added to the toolbox by default. Or you can do a Choose Items and select the component. 10.3 acts the same way.
https://ko.infragistics.com/community/blogs/b/taz_abdeali/posts/asp-net-product-changes contains more information about the asp.net product changes.
EDIT:
There is also a help article about all the asp.net controls:
http://help.infragistics.com/Doc/ASPNET/2010.3/CLR4.0/?page=Web_Where_Did_My_ASPNET_Controls_Go.html
