In my webdatagrid, I'm having a checkbox in each row and also in the header of that column.
On selection of the header check box all the check box of that column should get selected . Similar to this example http://samples.infragistics.com/2009.1/WebShowcase/MyMail/EmailClient.aspx. But I'm also having a event for row/cell selection changed. This event should not get firied when select the check box.
Please share the code for the mentioned link also.
Please let me know the resolution for this ASAP please.
Hello Romita,
You can download the source code of the samples from the following link :
http://ko.infragistics.com/dotnet/netadvantage/aspnet.aspx#Downloads = > right sidebar there is a link called “NetAdvantage for ASP.NET 2010 Vol. 3 Samples”
Thanks.
