640
identifying ID from cell in pivoted row
I need a way to assign multiple cells in each row their primary key ID that correlates with the primary key in the table after I pivot the data (which I am doing after I pull the records from the database - I'm creating the datatable manually).
For example, there is an orderID = 100 in the parent table, with these records in the child table:
In the database, there is one record per size/quantity:
ORDERID | Primary Key | Size | quantity
100 | SizeID1 | 9 | 12
100 | SizeID2 | 11 | 1
100 | SizeID3 | 15 | 8
I will create a datatable so that the records will look like this for the child rows in the grid:
ORDERID | Size 9 | Size 11 | Size 15
100 | 12 | 1 | 8
So when the user changes the value for Size 9 (in this case 12 units), I need to know that the cell that holds that quantity is 'SizeID1', and the cell that holds the '1' unit for size 11 is 'SizeID2', and so on.
How do I do that?
