70
ApplicationMenu2010 - ButtonTool: How to add ToolTip with Binding
Hi everybody,
I try to add a Tooltip to a ButtonTool, therefore I use the ButtonTool.Style:
<ig:ButtonTool.Style>
<Style TargetType="ig:ButtonToolControl">
<Setter Property="ToolTipService.ToolTip" Value="{Binding Path=[ToolTip_Menu_Exit],
Source={StaticResource SchedulerResources}, FallbackValue='Exit', TargetNullValue='Null'}" />
</Style>
</ig:ButtonTool.Style>
However, this ends in an exception when the window is initialized. The exception says that a read-only property can not be set. When I use a hard-coded value for the tooltip instead of the Binding it works. I need the binding for localization with .resx files.
Can anybody help? Thanks
Cheers, hp
