195
ultrawebtree does not cancel postback
When I run this app and click on a node, a prompt asks me if I want to continue.  If I click on 'Cancel', the POSTBACK stops as intended.  If I click on 'OK', the POSTBACK continues as it should.  However, once if I click on any nodes and I try cancelling the POSTBACK by clicking on 'Cancel', the POSTBACK continues!!  Why?  What am I doing wrong in this app??  Thanks for your help.
See app below:
 @ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="TestUltraWebTree._Default" %>
@ Register Assembly="Infragistics35.WebUI.UltraWebNavigator.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebNavigator" tagprefix="ignav" %>
@ Register Assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
html xmlns="http://www.w3.org/1999/xhtml" >
head runat="server">
<title>test app</title>
function tvwDevices_BeforeNodeSelectionChange() {
var changesMade = 'true' ;
if (changesMade == 'true' ) {var confirmLeave = window.confirm("You have unsaved changes. \n \n Are you sure you want to continue?"
if (confirmLeave) {
//parent.needtoSave(false);
else
//parent.needtoSave(true);
return true;
//true cancels postback
</script >
</ head >
body >
<form id="form1" runat ="server">
<div >
<asp:ScriptManager ID="ScriptManager1" runat ="server"> </asp:ScriptManager >
</div >
div id="splitterDIV" style ="width: 100%; height: 750px;">
<ig:WebSplitter ID="WebSplitter1" runat="server" Width="100%" Height ="100%">
<Panes >
<ig:SplitterPane Size="250px" CollapsedDirection ="PreviousPane">
<Template >
<ignav:UltraWebTree ID="tvwDevices" runat="server" DefaultImage="" HoverClass="" Indentation="5" Width ="140px">
<AutoPostBackFlags NodeChanged="True" NodeChecked="False" NodeCollapsed="False"
NodeDropped="False" NodeExpanded="False" />
<ClientSideEvents BeforeNodeSelectionChange="tvwDevices_BeforeNodeSelectionChange" />
<Levels >
<ignav:Level Index="0" />
<ignav:Level Index="1" />
</Levels >
<Nodes >
<ignav:Node Text ="Root Node">
<Nodes >
<ignav:Node Text="Yahoo" TargetUrl="http://www.yahoo.com" TargetFrame ="_content">
</ignav:Node >
<ignav:Node Text="Google" TargetUrl="http://www.Google.com" TargetFrame="_content">
</ignav:Node >
<ignav:Node Text="bing" TargetUrl="http://www.bing.com" TargetFrame="_content">
</ignav:Node >
<ignav:Node Text="dog pile" TargetUrl="http://www.dogpile.com" TargetFrame="_content">
</ignav:Node >
</Nodes >
</ignav:Node >
</Nodes >
</ignav:UltraWebTree >
</Template >
</ig:SplitterPane >
<ig:SplitterPane >
<Template >
<iframe name="_content" style ="width: 100%; height: 100%; border: none 0px; margin: 0px; padding: 0px;" frameborder="0" >
</iframe >
</Template >
</ig:SplitterPane >
</Panes >
</ig:WebSplitter >
</div>
</form >
body >
 html >
Parents
No Data
Reply
  • 49378
    Hi mrjdavilla,
    I know it has been a while since your post but in case you are still in need of assistance I would be glad to help.
    I investigated your scenario but was unable to spot any issues with your implementation. Here is the slightly modified javascript function I used:
            if (changesMade == 'true' ) {var confirmLeave = window.confirm("You have unsaved changes. \n \n Are you sure you want to continue?"); }
            if (confirmLeave) {
            return false;
            return true;
    Please do not hesitate to contact me if you have any questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
Children
No Data
