my xamcomboeditor is binded to an ObservableCollection<String> . The values are shown correctly, but on adding a value i always catch this exception:
Infragistics.RequireEmptyConstructorException: The DataManager attempted to create an instance of the type ‘System.String’ which does not have an empty parameter list.
I know new String() doesn't work, but isn't the xamcomboeditor able to add some strings to an normal colelction of strings?
<Editors:XamComboEditor IsEditable="True" ItemsSource="{Binding SuggestedValues, Mode=TwoWay}" CustomValueEnteredAction="Add" />
Hi UgaAga,
sorry for the late response.
There is no way for the XamComboEditor to create new object(by itself) if it does not have a default constructor.
For cases like this XamComboEditor expose an event called DataObjectRequested which is fired when new item should be constructed. In this event's handle you should create the new object and pass it by setting it to "e.NewObject". However this solution will not work in the case with "String" data type. It is not a good idea in general to use a Simple Types as a data source.
The only workaround I only can thing of is in that event handler to get the text that is typed in the editor by walking down the visual tree. After you have the string you can use it to cretae the String object and finally pass it to e.NewObject.
If you use a complex type and specify a DisplayMemberPath the XamComboEditor will set the DataObject's property after you have provided the newly created object from DataObjectRequested.
About the resources you have asked about - here a link to the help for XamComboEditor. You could take a look at the samples browser.
Regards
Is there a solution?
Where can i find a good tutorial, blog on xamComboEditor?
