I have an aspx page that has a Webgrid and also an ascx control. In the ascx page, user will be able to change the value and when they click "submit", i am updating the Grid control. I am doing so by using an delegate. There are problems that i face
1) When i load the default values in the Grid, it work fine, but when i click on the "Submit" button in the ascx page, the Grid is not updating to the new result, even though i bind the Grid with the new Dataset. Wht could be the problem?
2) For example, i have set the default value to 30 records, and i am scrolling down and viewing records that is more that 30. Now when i click on the "Submit" button and it fetches new records, i want 2 things to happen, First, i want the scroll position to be in the first record and Second i want to show only 30 records. ie., If i already viewed 90 records and the new Dataset has 340 records, wht it does is that in the grid, it shows the 90 records, and it will fetch only when i scroll down. I donot want that to happen, instead it should show only 30 records.
Please find the code below..
ASPX Page CS FILE
using System;using System.Data;using System.Configuration;using System.Collections;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;using System.Web.UI.HtmlControls;using System.Diagnostics;using Infragistics.WebUI;namespace PLXG{ public partial class WMS_Advance_Search : System.Web.UI.UserControl { protected void Page_Load(object sender, EventArgs e) { } protected override void OnInit(EventArgs e) { this.UltraWebGrid1.Browser = BrowserLevel.Xml; this.UltraWebGrid1.DisplayLayout.LoadOnDemand = LoadOnDemand.Xml; this.UltraWebGrid1.DisplayLayout.XmlLoadOnDemandType = XmlLoadOnDemandType.Virtual; this.UltraWebGrid1.DisplayLayout.RowsRange = 30; this.UltraWebGrid1.InitializeDataSource += new InitializeDataSourceEventHandler(UltraWebGrid1_InitializeDataSource); base.OnInit(e); } void UltraWebGrid1_InitializeDataSource(object sender, UltraGridEventArgs e) { BindGrid(); } private void BindGrid() { // Connect to SQL Northwind database SqlConnection con = new SqlConnection(@"data source=localhost;User ID=raja;password=raja;"); // Get data between current row and row range provided by event args SqlCommand comm = new SqlCommand(@" select * from wms_activityhistory " , con); SqlDataAdapter da = new SqlDataAdapter(comm); DataTable dt = new DataTable(); da.Fill(dt); // Set requested data for grid this.UltraWebGrid1.DataSource = dt; } private void GetPartialData(string searchword, int companyid) { // Connect to SQL Northwind database SqlConnection con = new SqlConnection(@"data source=localhost;User ID=raja;password=raja;"); // Get data between current row and row range provided by event args SqlCommand comm = new SqlCommand(@" select * from wms_activityhistory WHERE companyid = " + companyid + "text like '%" + searchword + "%'", con); SqlDataAdapter da = new SqlDataAdapter(comm); DataTable dt = new DataTable(); da.Fill(dt); // Set requested data for grid this.UltraWebGrid1.DataSource = dt; } public void onSearchBtnClick(SearchWord, CompanyId) { GetPartialData(SearchWord,CompanyId); } }}
ASCX page
<%@ Control Language="C#" AutoEventWireup="true" CodeBehind="WMS_Advance_Search.ascx.cs" Inherits="PLXG.WMS_Advance_Search" %><%@ Register Assembly="Infragistics2.WebUI.WebDataInput.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.WebDataInput" TagPrefix="igtxt" %><%@ Register Assembly="Infragistics2.WebUI.Misc.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.Misc" TagPrefix="igmisc" %><%@ Register Src="WMS_ProgressWindow.ascx" TagName="WMS_ProgressWindow" TagPrefix="uc2" %><script language="javascript" src="scripts/WebAsyn.js" type="text/javascript"></script><script id="Infragistics" type="text/javascript"><!-- function btnClose_Filter_Click(oButton, oEvent) { CloseFilter(); oEvent.cancel=true; oEvent.cancelPostBack=true; } function CloseFilter() { CloseSearch(); } function splDV_ctl01_ctl01_pnlSearch_InitializePanel(oPanel) { WebAsyn_InitializePanel(oPanel); } function pnlSearch_RefreshComplete(oPanel) { myDialog.Close(); eventsAfterRefreshComplete(); } function eventsAfterRefreshComplete() { ChangeWpnl('splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany'); var obj=document.getElementById('<%=hdnAdvancedOption.ClientID%>'); if(obj.value == "1") { ShowAdvancedOption(); } else { HideAdvancedOption(); } } function ChangeWpnlImage(oWebPanelClientId) { var WebPanelHeaderImage = oWebPanelClientId + "_chk" document.getElementById(WebPanelHeaderImage).checked = true; InitializeWepPanel(oWebPanelClientId); } function ChangeWpnl(oWebPanelClientId) { var objPanel =igpnl_getPanelById(oWebPanelClientId); if(objPanel.getExpanded()) { var WebPanelHeaderImage = oWebPanelClientId + "_chk" document.getElementById(WebPanelHeaderImage).checked = true; if(oWebPanelClientId == 'splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany') { var Company1 = document.getElementById("<%=ddlCompany.ClientID%>"); var idxCompany1 = Company1.selectedIndex; var valCompany1=Company1.options[idxCompany1].value; if(valCompany1==0)//all { document.all['ImgBtn_Company'].style.visibility='hidden'; } else { document.all['ImgBtn_Company'].style.visibility='Visible'; } } } } function InitializeWepPanel(oWebPanelClientId) { if(oWebPanelClientId == 'splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany') { document.getElementById("<%=ddlCompany.ClientID%>").selectedIndex = 0; //document.all['ImgBtn_Company'].style.visibility='hidden'; document.getElementById("<%=txtCompany.ClientID%>").value = "ALL"; document.getElementById("<%=txtCompanyID.ClientID%>").value = "0"; //document.getElementById("<%=txtCompany.ClientID%>").readOnly=true; } } var expandWebPanel = ""; function ExpandCollapsePanel(webPanelID) { expandWebPanel = "expand"; var objPanel =igpnl_getPanelById(webPanelID); objPanel.setExpanded(!objPanel.getExpanded()); if(webPanelID == "splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany") { var CmpPanel =igpnl_getPanelById('splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany'); if(CmpPanel.getExpanded()) { document.getElementById("<%=ddlCompany.ClientID%>").selectedIndex = 0; document.all['ImgBtn_Company'].style.visibility='hidden'; document.getElementById("<%=txtCompany.ClientID%>").value = "ALL"; document.getElementById("<%=txtCompanyID.ClientID%>").value = "0"; } if(!CmpPanel.getExpanded()) { document.getElementById("<%=txtCompanyID.ClientID%>").value = "ALL" } //document.getElementById("<%=txtCompany.ClientID%>").readOnly=true; } } function fnddlCompany() { var Company = document.getElementById("<%=ddlCompany.ClientID%>"); var idxCompany = Company.selectedIndex; var valCompany=Company.options[idxCompany].value; // document.getElementById("<%=txtCompany.ClientID%>").readOnly=false; if(valCompany==0)//all { document.all['ImgBtn_Company'].style.visibility='hidden'; document.getElementById("<%=txtCompany.ClientID%>").value = "ALL"; document.getElementById("<%=txtCompanyID.ClientID%>").value = "ALL"; } else if(valCompany==1) { if(document.getElementById("<%=txtCompany.ClientID%>").value == "ALL") { document.getElementById("<%=txtCompany.ClientID%>").value = ""; } document.all['ImgBtn_Company'].style.visibility='Visible'; } //document.getElementById("<%=txtCompany.ClientID%>").readOnly=true; } function newWin(url) { var Return = ShowDialog(url); if(Return != null) { if(Return.Name == "'ALL'") { Return.Name = Return.Name.replace("'",""); } if(Return.sessionid == "Company") { // document.getElementById("<%=txtCompany.ClientID%>").readOnly=false; document.getElementById("<%=txtCompany.ClientID%>").value = Return.Name; document.getElementById("<%=txtCompanyID.ClientID%>").value = Return.ID; //document.getElementById("<%=txtCompany.ClientID%>").readOnly=true; } } } function HideAdvancedOption() { trAdvancedOption.style.display = 'none'; document.getElementById("<%=tdImgCollapse.ClientID%>").style.display='none'; document.getElementById("<%=tdImgExpand.ClientID%>").style.display='block'; var obj=document.getElementById('<%=hdnAdvancedOption.ClientID%>'); obj.value = "0"; } function ShowAdvancedOption() { trAdvancedOption.style.display = 'block'; document.getElementById("<%=tdImgCollapse.ClientID%>").style.display='block'; document.getElementById("<%=tdImgExpand.ClientID%>").style.display='none'; var obj=document.getElementById('<%=hdnAdvancedOption.ClientID%>'); obj.value = "1"; } function wbtn_Search_Click(oButton, oEvent){ if(document.getElementById("<%=txtSearchWord.ClientID%>").value.replace(/^\s+|\s+$/g, '') == "") { alert("Please enter the search word"); document.getElementById("<%=txtSearchWord.ClientID%>").focus(); oEvent.cancel=true; oEvent.cancelPostBack=true; return; } if(document.getElementById("<%=txtSearchWord.ClientID%>").value.length < 4) { alert("Please enter minimum 4 char(s)"); oEvent.cancel=true; oEvent.cancelPostBack=true; return; } if((document.getElementById("<%=ddlCompany.ClientID%>").selectedIndex == 1) && (document.getElementById("<%=txtCompany.ClientID%>").value.replace(/^\s+|\s+$/g, '') == "")) { alert("Please select the company"); oEvent.cancel=true; oEvent.cancelPostBack=true; return; }}function clickButton(e, buttonid){ if (e.keyCode == 13) { if(document.getElementById("<%=txtSearchWord.ClientID%>").value.replace(/^\s+|\s+$/g, '') == "") { alert("Please enter the search word"); document.getElementById('<%=txtSearchWord.ClientID%>').focus(); return false; } else { document.getElementById("<%=wbtn_Search.ClientID%>").click(); document.getElementById('<%=txtSearchWord.ClientID%>').focus(); return false; } } }function WebTextEdit1_Focus(oEdit, text, oEvent){ var editor = igedit_getById("splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlwo_txtWOs"); if(editor.getText()== "ALL") editor.setText("");}// --></script><table style="width:100%; height:100%" cellpadding="0" cellspacing="0"><tr><td style="border-bottom:solid 1px black; height:22px;" class="commonCustomiseTopHeader"><table width="100%" cellpadding="0" cellspacing="0"> <tr valign="top" style="width:100%;height:22px;" class="Heading"> <td valign="middle"> <asp:Label id="Label1" SkinID="CCELabel" runat="server" Font-Bold="true" Text="Search Options" ></asp:Label> </td> <td align="right"> <igtxt:WebImageButton ID="btnClose_Filter" Visible="true" SkinID = "CCEWebClose" runat="server" Text="" UseBrowserDefaults="False" ToolTip ="Close the Search Option window" AutoSubmit="false"> <ClientSideEvents Click="CloseFilter();" /> </igtxt:WebImageButton> </td> </tr></table></td></tr><tr valign="top"><td> <table style="width: 100%" cellpadding="0" cellspacing="0" border="0"> <tr style="height: 100%"> <td style="height: 100%;padding-top:3px;" id="tdMain" runat="server" > <asp:Panel ID="Panel2" runat="server" SkinID="CCEPanel" Height="24px" Width="248px"> <table id="Table1" cellpadding="0" cellspacing="0" border="0" width="100%" style="padding-top: 5px; padding-bottom: 5px"> <tr> <td style="width: 94px"> <asp:Label ID="lblSearchWord" SkinID="CCELabel" runat="server" Width="89px" Text="Search by word"></asp:Label> </td> <td style="padding-left:10px;font-family:Verdana;font-size:9px; color: dimgray;padding-top:10px;"> <asp:TextBox ID="txtSearchWord" SkinID="CCETextBox" runat="server" ></asp:TextBox> (Minimum 4 chars) </td> </tr> </table> </asp:Panel> </td> </tr> <tr> <td> <table cellpadding="0" cellspacing="0" border="0" width="100%"> <tr> <td> <igmisc:WebAsyncRefreshPanel ID="splDV_ctl01_ctl01_pnlSearch" runat="server" Width="99%" LinkedRefreshControlID="Pnl_GridSearch" RefreshComplete="pnlSearch_RefreshComplete" InitializePanel="splDV_ctl01_ctl01_pnlSearch_InitializePanel"> <table width="100%" cellpadding="0" cellspacing="0" border="0"> <tr valign="top" style="width:100%;"> <td valign="top" style="padding-top:10px;"> <table width="100%" style="height:16px" cellpadding="0" cellspacing="0" border="0"> <tr valign="top" style="width:100%;" class="Heading"> <td valign="middle"> <asp:Label ID="Label4" SkinID="CCELabel" runat="server" Font-Bold="true" Text="Advanced Search Options"></asp:Label> </td> <td align="right"> <table> <tr> <td runat="server" id="tdImgExpand"> <img id="ImgExpand" title="click here to expand Advanced Search Option" style="cursor: hand;" onclick="ShowAdvancedOption()" src="App_Themes/CCEPLXGNewStyles/Images/srchExpand.gif" width="16" alt="" /> </td> <td runat="server" id="tdImgCollapse"> <img id="ImgCollapse" title="click here to collapse Advanced Search Option" style="cursor:hand;" onclick="HideAdvancedOption()" src="App_Themes/CCEPLXGNewStyles/Images/srchCollapse.gif" width="16" alt="" /> </td> </tr> </table> </td> </tr> </table> </td> </tr> <tr id = "trAdvancedOption"> <td style="height: 100%" id="td1" runat="server"> <asp:Panel ID="Panel1" runat="server" SkinID="CCEPanel" Height="100%"> <igmisc:WebPanel ID="wpnlcompany" runat="server" ExpandEffect="None"> <ClientSideEvents ExpandedStateChanging="expanding"></ClientSideEvents> <Header Text="<INPUT id="splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany_chk" onclick="ExpandCollapsePanel('splDV_ctl00_ctl01_WMS_Advance_Search1_wpnlcompany')" type=checkbox value="ON"/>Company" TextAlignment="Left"> <ExpandedAppearance> <Style CssClass="ccefiltercommon"> </Style> </ExpandedAppearance> <CollapsedAppearance> <Style CssClass="ccefiltercommon"> </Style> </CollapsedAppearance> <ExpansionIndicator Height="0px" Width="0px" /> </Header> <Template> <table cellpadding="0" cellspacing="0" border="0"> <tr id="tr1"> <td style="padding-left: 20px"> <asp:DropDownList ID="ddlCompany" SkinID="CCEDropdown" runat="server" Width="125px"> <asp:ListItem Value="0" Selected="True">-------- All ---------</asp:ListItem> <asp:ListItem Value="1">In</asp:ListItem> </asp:DropDownList> </td> </tr> <tr> <td height="1"> </td> </tr> <tr> <td style="padding-left: 20px;" valign="top"> <asp:TextBox ID="txtCompany" SkinID="CCETextBox" runat="server" Width="200px"></asp:TextBox> </td> <td id="TdImgBtn_Company" runat="server" style="width: 25px; padding-left: 4px;"> <img id="ImgBtn_Company" title="click on this button to bring up the list of companies to filter" style="cursor: hand; visibility:hidden" onclick="BLOCKED SCRIPT var companyName = document.getElementById('<%=txtCompanyID.ClientID%>').value; newWin('WMS_SearchPopup.aspx?srch=Company&txtValue='+companyName)" src="App_Themes/CCEPLXGNewStyles/Images/getsearch.gif" width="25" alt=""> </td> <td valign="top"> <asp:TextBox ID="txtCompanyID" SkinID="CCETextBox" runat="server" Width="0px"></asp:TextBox> </td> </tr> </table> </Template> <PanelStyle Height="10px"> </PanelStyle> </igmisc:WebPanel> </asp:Panel> </td> </tr> <tr> <td height="40px" align="center" valign="middle"> <table cellpadding="0" cellspacing="0" class="ccebtntable"> <tr> <td> <igtxt:WebImageButton ID="wbtn_Search" SkinID="CCEWebImgBtn" runat="server" ToolTip="Click here to Search" Text="Search" AutoSubmit="true" OnClick="wbtn_Search_Click" Focusable="true" ClickOnEnterKey="false" > <ClientSideEvents Click="wbtn_Search_Click" /> </igtxt:WebImageButton> </td> <td> <igtxt:WebImageButton ID="wbtnCancel" SkinID="CCEWebImgBtn" runat="server" ToolTip="Click here to Close the Search window" Focusable="False" Text="Cancel" Width="92px" CausesValidation="False" ClickOnEnterKey="false" AutoSubmit="false"> <ClientSideEvents Click="CloseFilter();" /> </igtxt:WebImageButton> </td> </tr> </table> </td> </tr> </table> </igmisc:WebAsyncRefreshPanel> </td> </tr> </table> </td> </tr> </table> </td></tr></table><input type="hidden" runat="server" id="hdnTimePeriod" style="width: 0px" /><input type="hidden" id="hdnAdvancedOption" runat="server" style="width: 0px" />
ASCX Cs File
using System;using System.Data;using System.Configuration;using System.Collections;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;using System.Web.UI.HtmlControls;using System.Diagnostics;namespace PLXG{ public partial class WMS_Advance_Search : System.Web.UI.UserControl { protected void Page_Load(object sender, EventArgs e) { } protected void wbtn_Search_Click(object sender, Infragistics.WebUI.WebDataInput.ButtonEventArgs e) { searchWord_Filter(); } private void searchWord_Filter() { try { string SearchWord = ""; string CompanyId = "0"; SearchWord = this.txtSearchWord.Text; //Company if (wpnlcompany.Expanded) { if (this.txtCompany.Text == "All Companies" || this.txtCompany.Text == "ALL") { CompanyId = "0"; } else { CompanyId = txtCompanyID.Text.ToString(); } } else // If the Company Filter is empty then save as 0. { CompanyId = "0"; } OnSearchBtnClick(SearchWord, CompanyId); } catch (Exception ex) { Debug.WriteLine(ex.ToString()); } } #region SearchBtnClick delegates and events public delegate void onSearchBtnClickHandler(string SearchWord, string CompanyId); public event onSearchBtnClickHandler onSearchBtnClick; protected virtual void OnSearchBtnClick(string SearchWord, string CompanyId) { if (onSearchBtnClick != null) { onSearchBtnClick(SearchWord, CompanyId); } } #endregion }}
Please help me out? Is there a solution for the above problem?
Raja
Hello Raja,
It has been a while since you have made your post, but I suppose the other community members can benefit from this answer as well.
In order to implement Partial Data Binding functionality properly you can follow this article that shows step-by-step guide with code snippets included - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/WebGrid_Partial_Data_Binding.html
In order to position the grid scroll on the needed record you can use “ScrollTop Property” property - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/Infragistics4.WebUI.UltraWebGrid.v10.3~Infragistics.WebUI.UltraWebGrid.UltraGridLayout~ScrollTop.html - or you can use “scrollToView()” function to scroll to specific row or cell:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/WebGrid_Scroll_a_Row_into_View.html
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/WebGrid_Scroll_a_Cell_into_View.html
I hope that this information will be helpful.
