Hi there,
I am using the Infragistics WebGrid and can't seem to find DisplayLayout even though this has been specified in the documentation.
I am using Visual Studio 2008 and CLR 3.5. This is the tag that appears in the html file.
<ig:WebDataGrid ID="_grid" runat="server" Height="350px" Width="766px" >
I saw that someone was the same problem in the forum and a sample solution was posted. In that solution, the tags were different. I download the sample solution and couldn't run it.
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="303px" >
I just downloaded the Ultimate Package and installed the .NET Controls. What is causing this problem ?
Hi davidhathome,
It has been a while since your post, however in case you still need assistance I would be glad to help.
Please note that the UltraWebGrid and the WebDataGrid are different controls. As such the WebDataGrid control does not feature a display layout property.
You can find more information about the WebDataGrid in our documentation at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
The documentation for the UltraWebGrid is available at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Web_WebGrid.html
Please let me know if I can be of further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
