Testing in IE9 on win7-32 bit, the webdatechooser popup shows up behind the webdialog where it is located. The same code works fine on IE6 thru IE8, Firefox, Chrome, and Safari. I am using Infragistics35.WebUI.WebDateChooser.v10.2, Version=10.2.20102.1011. Is this a known issue and is there a workaround?thanks,_matt_
Hallo,
Problem occurs, when Modal="true" on WebDialogWindow.
Markus
Hello Matt,
I tested your sample code snippet with the last service release of 10.3 verion using Internet Explorer 8
and it is working fine without adding Z-index of the WebDateChooser.
I am sure that the scenario will be tested and verified in IE9 as soon as we officially support it :
http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
Let us know if you need further assistance regarding this.
Hello Bhadresh, I used your markup and there was no issue and Compatibility View had no affect. I ripped just the important bits from my major application in production and the pop-up hidden issue was still there. Below is my test markup. I had to add the Z-index setting on the date chooser since the calender did not show up on an earlier version of the app with earlier IG dlls, versions of IE, and versions of IIS. Unless this was a known bug which has been fixed in the V10.3 for .net3.5 and .net4.0, I would prefer not to have to test all of the permutations of browsers and IIS again after removing the Z-index and then find it breaks in another configuration. On a separate thread, I posted a request to reverse the order on the year drop down which is a higher priority for me at the moment.
<%@ Page Language="C#" AutoEventWireup="false" CodeBehind="Test.aspx.cs" Inherits="X.XX.Test" EnableViewState="False" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title></title> <script language="javascript" type="text/javascript"> function Button1_onclick() { var Dialog = $find("WebDialogWindow1"); Dialog.show(); } function Button2_onclick() { var Dialog = $find("WDW1"); Dialog.show(); } </script></head><body> <form id="form1" runat="server"> <ig:WebScriptManager ID="WebScriptManager1" runat="server"> </ig:WebScriptManager> <ig:WebDialogWindow ID="WebDialogWindow1" runat="server" Height="336px" WindowState="Hidden" InitialLocation="Centered" Width="438px"> <ContentPane> <Template> <div id="main"> <div style="float:left"> <ig:WebDatePicker ID="WebDatePicker1" runat="server"> </ig:WebDatePicker> </div> <div style="float:left; margin-left:20px"> <igsch:WebDateChooser ID="WebDateChooser1" runat="server"> </igsch:WebDateChooser> </div> <div style="clear:left"></div> </div> </Template> </ContentPane> </ig:WebDialogWindow>
<ig:WebDialogWindow runat="server" ID="WDW1" Modal="True" EnableViewState="False" Height="330px" Width="660px" InitialLocation="Centered" WindowState="Hidden"> <Header CaptionText="Options"> <MaximizeBox AltText="Maximize"></MaximizeBox> <MinimizeBox AltText="Minimize"></MinimizeBox> <CloseBox Visible="False" /> </Header> <ContentPane> <Template> <table style="height: 100%; width: 100%;" cellspacing="0" cellpadding="0"> <tr> <td> <table width="100%"> <tr> </tr> <tr> <td> <asp:Label runat="server" ID="labelFrom" Text="From date:" /> <br /> <igsch:WebDateChooser ID="WDTC1" Style="z-index: 101" runat="server" Width="120px" NullDateLabel=" " Height="19px" MinDate="1990-01-01" MaxDate='2100-01-01' Format="Short"> </igsch:WebDateChooser> <br /> <asp:Label runat="server" ID="labelThrough" Text="Through date:" /> <br /> <igsch:WebDateChooser ID="WDTC2" Style="z-index: 101" runat="server" Width="120px" NullDateLabel=" " Height="19px" MinDate="1990-01-01" MaxDate='2100-01-01' Format="Short"> </igsch:WebDateChooser> </td> <td> </td> </tr> <tr> </tr> </table> </td> </tr> <tr style="vertical-align: bottom"> </tr> </table> </Template> </ContentPane> </ig:WebDialogWindow> </form> <p> <input id="Button1" type="button" value="button" onclick="return Button1_onclick()" /></p> <p> <input id="Button2" type="button" value="button bad" onclick="return Button2_onclick()" /></p></body>
</html>
thanks,
Matt
Were you able to duplicate the issue on IE 9 using the mark up and JavaScript I have provided? Update me with screenshot of the behavior so I may investigate this further.
Bhadresh
Hi Bhadresh,Thanks for investigating. I was able to duplicate my original issue but then switched the IE browser to Compatibility View on and the issue went away. To date, this is the only combination I need to use Compatibility View.Matt
