1060
Button Command in Template Column
Hello
Has anybody got an example of a XamGrid that successfully uses commanding on a button within the item template of a template column?
I have tried Prism commands and Silverlight ICommands with no luck.  The command fires OK in my viewmodel when I move the button outside of the XamGrid but not when it's in the column template. When i have done this before within in a listbox itemtemplate the addition of ElementName=LayoutRoot and adding DataContext to the binding path has worked but it doesn't seem to in this case.
Here's my XAML.
                <ig:TemplateColumn Key="AliasId"
                                   Width="Auto"
                                   HorizontalContentAlignment="Center"
                                   HeaderTextHorizontalAlignment="Center">
                    <ig:TemplateColumn.HeaderTemplate>
                        <DataTemplate>
                            <TextBlock Text="{Binding ItemAliasStrings.DeleteColumn, Source={StaticResource ItemAliasStrings}}"></TextBlock>
                        </DataTemplate>
                    </ig:TemplateColumn.HeaderTemplate>
                    <ig:TemplateColumn.ItemTemplate>
                        <DataTemplate>
                            <Button cal:Click.Command="{Binding DataContext.DeleteCommand, ElementName=LayoutRoot}"
                                    Content="{Binding ItemAliasStrings.DeleteColumn, Source={StaticResource ItemAliasStrings}}"
                                    Margin="5,0,5,0" />
                        </DataTemplate>
                    </ig:TemplateColumn.ItemTemplate>
                </ig:TemplateColumn>
Kevin
