Is there a way to get the rowadded event to fire when the grid loses focus as opposed to when tabbing to a new row?
I double checked what I have. I think the issue may be is that the grid can't 'lose focus' if its inside the wizard control I'm using (http://silverlightwizard.codeplex.com/). I found a work around for what I needed though.
"If you're in edit mode of an AddNewRow, event will already fire when the xamgrid looses focus. It actually happens as soon as the row loses focus. "
I think there are scenarios where this isn't the case. I'll see if I can get some reproducible code.
As for controlling the specific circumstances, thats not really possible. I suppose you could try listening to the ActiveCellChanging event, and cancel it if you're currently editing an AddNewRow.
-SteveZ
