3305
is there a way to programmaically tell if a column has been sorted?
I have a grid that uses external "Add"Row" controls all works fine if the grid sort is the "Default"
however if you swith the sort and they are now descending this code won't work
case "AddValue"
QualificationValue val = QualificationValue
.CreateNew();
val.QualificationID = _vm.SelectedQualificationList.QualificationID;
val.ItemValue =
_vm.obsValueList.Insert(
, val);
try
Row r = grdSelectedVals.Rows[0
Cell c = (Cell)r.Cells[1
r.IsSelected =
true
grdSelectedVals.EnterEditMode(r, c);
grdSelectedVals.IsEnabled =
true
_vm.IsDirty =
true
catch (Exception
ex)
throw
ex;
it will go the the first row in the grid and relapce the exisitn value.
is there a wasy I can test the sort of the column so i know whether or not to select row ")" or the last row in the grid?
