I have a webgrid with calculative column with formula attached. The formula is depending on some other column.
Say ColA,ColB.
ColB.Formula = [ColA]*8.345;
Now the problem is, If the value in the ColA is null, then ColB cells are returning 0 as the value instead of null.
How do I override this behaviour so that calculative columns cells are not defaulted to 0.
