80
Horizontal XamMenu Data binding with HierarchicalData
Hi ,
I want to Display XamMenu horizontally with HierarchicalData as datasource. It  should support
navigation also. the following code works fine but it is not diaplying horizontally. Please help me in this.
my:XamMenu.HierarchicalItemTemplate
<ig:HierarchicalDataTemplate ItemsSource="{Binding Path
=Children}">
<ig:HierarchicalDataTemplate.DefaultItemsContainer
<DataTemplate>
<my:XamMenuItem NavigationOnClick
="True"
NavigationUri="{Binding PageURL
NavigationElement="{Binding ElementName=menuFrame}"
StaysOpenOnClick
="True">
<my:XamMenuItem.Header
<TextBlock Text="{Binding Name
</my:XamMenuItem.Header>
</my:XamMenuItem>
</DataTemplate
</ig:HierarchicalDataTemplate.DefaultItemsContainer>
<DataTemplate
<StackPanel Orientation
="Horizontal">
<my:XamMenuItem Header="{Binding Name}" MenuOrientation="Horizontal" StaysOpenOnClick
="True">
</my:XamMenuItem
</StackPanel
</DataTemplate>
</ig:HierarchicalDataTemplate>
</my:XamMenu.HierarchicalItemTemplate
</my:XamMenu
  • 6475
    Verified Answer
    You shouldn't place a XamMenuItem in your ItemTemplate. A XamMenuItem will be created as a container for the DataTemplate you provide, which means you'll end up having XamMenuItem inside a XamMenuItem. So, you'll have a XamMenuItem with MenuOrientation set to "Horizontal" inside of another XamMenuItem, generated as a container to host the one you specified in your  DataTemplate. And the Parent one will have it's MenuOrientation set to the default value (which is Vertical). Instead, you could specify a DefaultItemsContainer, which will be used when generating the container items.
    So your code should look something like this:
            <ig:XamMenu x:Name="igMenu" Height="30" Margin="10" ItemsSource="{StaticResource data}">
                <ig:XamMenu.DefaultItemsContainer>
                    <DataTemplate>
                        <ig:XamMenuItem MenuOrientation="Horizontal" />
                    </DataTemplate>
                </ig:XamMenu.DefaultItemsContainer>
                <ig:XamMenu.HierarchicalItemTemplate>
                    <ig:HierarchicalDataTemplate ItemsSource="{Binding Path=Children}">
                        <ig:HierarchicalDataTemplate.DefaultItemsContainer>
                            <DataTemplate>
                                <ig:XamMenuItem NavigationOnClick="True"
                                                NavigationUri="{Binding PageURL}"
                                                StaysOpenOnClick="True">
                                </ig:XamMenuItem>
                            </DataTemplate>
                        <ig:HierarchicalDataTemplate.ItemTemplate>
                            <DataTemplate>
                                <TextBlock Text="{Binding Name}" />
                            </DataTemplate>
                        </ig:HierarchicalDataTemplate.ItemTemplate>
                        <DataTemplate>
                        </DataTemplate>
                </ig:XamMenu.HierarchicalItemTemplate>
            </ig:XamMenu>
    Hope this helps,
