Hi
We've recently updated our controls from 2004.2 to 2010.3 and there seems to be an issue with IE6 and the WebDateChooser. Clicking on the dropdown arrow, gives a javascript "Unspecfied Error". The line number doesn't seem to correspond to the problem
Is this a known problem? Are there any workarounds?
Hi Keltyx,
Thank you for your reply.
Please contact me if I can be of further assistance.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
The issue turned out to be that IE6 on Windows Server 2003 is not the same as IE6 on Windows XP.
There's no real resolution, just that in our scenario anyone using IE6 will be using it from Windows XP.
Regards
It has been a while since your post, however in case you still need assistance I would be glad to help.
Please refer to the following discussion as it provides some suggestions for issues with the WebDataChooser in IE6:
https://ko.infragistics.com/community/forums/f/retired-products-and-controls/38718/webdatechooser-drop-down-calendar-not-displaying-in-ie-6
Please let me know if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.https://ko.infragistics.com/support
