220
Resource name not visible on the left side
I have used the xamScheduleView to display the following view (see attached). However am not able to see the resource i.e. (Amanda and Deven) in the UI.
The code that it used is as under:
//add a resources list with one resource inside
var resources = new ObservableCollection<Resource>();
resources.Add(new
Resource
Id =
"own1",
Name = "Amanda",
IsVisible = true
resources.Add(
new
Resource
Id = "own2",
Name = "Deven",
IsVisible = true
//Create a resource calendar list with one calendar inside
//Note that the owning resource id of the calendar is the same as the id of the resource created in the previous step.
var calendars = new ObservableCollection<ResourceCalendar>();
calendars.Add(
new
ResourceCalendar
Id =
"cal1",
OwningResourceId = "own1"
calendars.Add(
new
ResourceCalendar
Id = "cal2",
OwningResourceId = "own2"
//Create a list of appointments with three items inside:
//Note that the appointments' resource id is the same as the resources defined, and the calendar id is the same as the calendar defined in step 5.
var appointments = new ObservableCollection<Appointment>();
appointments.Add(new Appointment
Id = "t1",
OwningCalendarId = "cal1",
OwningResourceId = "own1",
Subject = "Appointment 1",
Description = "My first appointment",
Start = DateTime.Today.AddHours(1).ToUniversalTime(),
End = DateTime.Today.AddHours(2).ToUniversalTime()
Id = "t2",
Subject = "Appointment 2",
Description = "My second appointment",
Start = DateTime.Today.AddHours(3).ToUniversalTime(),
End = DateTime.Today.AddHours(4).ToUniversalTime()
Id = "t3",
OwningCalendarId = "cal2",
OwningResourceId = "own2",
Subject = "Appointment 3",
Description = "My third appointment",
Start = DateTime.Today.AddHours(5).ToUniversalTime(),
End = DateTime.Today.AddHours(6).ToUniversalTime()
//Create a xamSchedule Data Connector and attach the list of resources, calendars and appointments to it:
ListScheduleDataConnector scheduleDataConnector =
new ListScheduleDataConnector();
scheduleDataConnector.ResourceItemsSource = resources;
scheduleDataConnector.ResourceCalendarItemsSource = calendars;
scheduleDataConnector.AppointmentItemsSource = appointments;
//Create a xamSchedule Data manager and attach the Data Connector to it:
XamScheduleDataManager scheduleDataManager = new XamScheduleDataManager();
scheduleDataManager.DataConnector = scheduleDataConnector;
//Create a calendar group and set the initial calendar:
CalendarGroupCollection calGroups = scheduleDataManager.CalendarGroups;
CalendarGroup calGroup = new CalendarGroup();
calGroup.InitialCalendarIds = "own1[cal1],own2[cal2]";
calGroup.InitialSelectedCalendarId = "own1[cal1]";
calGroups.Add(calGroup);
//Finally create a xamSchedule DayView, attach the data manager to it
//XamDayView xamDayView1 = new XamDayView();
xamScheduleView1.DataManager = scheduleDataManager;
//this.PageRoot.Children.Add(xamDayView1);
However the resource names are displayed. Can somebody please help...
