167
Memory leak reported by sIEve
   while I was performing a bit of memory profiling on a web application of mine, I've found an issue with your grid (UltraWebGrid v.7.3)
I've reduced the problem to a very simple page and created a visual studio solution for it.
By the end, the problem arises when the grid is inside an iframe and you start posting back the page. Every time you click, you'll see that sIEve will report a new set of leaks. These leaks are about some tags of your like "ClientState", "DisplayLayout", "StateChanges" and "UltraWebGrid".
May you tell me if you have ever experienced such an issue?
Best regards, Andrea
WebApplication4.zip
