I have a DateTimeRangeSlider with a LargeChangeType of Years and a SmallChangeType of months. The DateTimeSliderTickMarks are set to months. Given this configuration, I would expect that each time I move a slider one tick, the date range would display the first of the appropriate month.
What I am seeing however is that the slider appears to be "off" by several days, to the point where moving the slider several ticks causes it to stop between tickmarks.
I have included a screenshot of my date output as well as my xaml below. Thank you in advance for your time.
<ig:XamDateTimeRangeSlider Grid.Row="1" Grid.Column="0" Grid.ColumnSpan="2" x:Name="slider" MinValue="1/1/2000" MaxValue="1/1/2010" IsSelectionRangeEnabled="True" IncreaseButtonVisibility="Collapsed" DecreaseButtonVisibility="Collapsed" VerticalAlignment="Bottom" Margin="5" LargeChangeType="Years" LargeChange="1" SmallChangeType="Months" SmallChange="1"> <ig:XamDateTimeRangeSlider.TickMarks> <ig:DateTimeSliderTickMarks FrequencyType="Months" TickMarksFrequency="1" IncludeSliderEnds="True" /> </ig:XamDateTimeRangeSlider.TickMarks> <ig:XamSliderDateTimeThumb Value="{Binding Text, ElementName=stop1, Mode=TwoWay}" IsSnapToTickEnabled="True" /> <ig:XamSliderDateTimeThumb Value="{Binding Text, ElementName=stop2, Mode=TwoWay}" IsSnapToTickEnabled="True" /> </ig:XamDateTimeRangeSlider>
This issue has been fixed by our Engineering team, and will be addressed by the next Silverlight /LoB Service Release, which is projected for release on May 16 for versions 10.1, 10.2, and 10.3, according to the schedule posted at:
http://ko.infragistics.com/support/service-releases.asp
I am experiencing a similar issue with XamNumericRangeSlider. What is the status of this bug?
willmiller,
I have created the support case and linked it to Development Issue 62170, so you will be notified when the issue has been addressed.
This appears to be a bug in the control. I have submitted a bug for this issue and it is currently in review by our developers.
I will contact our Developer Support team and have them link you to this bug so you can be notified when it's fixed.
- Pamela
