50
auto horizontal scrolling
 In my application I am using WebHTMLEditor
the height is steady   so when user insert  too many rows a scrollbar appears - 2 scrollbars!! horizontal and  vertical eventhoght the rows are short  and the  horizontal one are not supposed to be
 more the  this: in my local it works fine - just the vertical scroll appear. this bug occur only when the page published to the web
any idea?
I am using  version 10.3.20103.2046
Thanks!
Shlomit
  • 10
    Suggested Answer
    Shlomit,
    To fix the overflow issue set the CssClass' property (under the TextWindow) of the HtmlWebEditor,
    Check my post - http://narsimlusblog.blogspot.com/2011/01/overflow-issue-in-infragistics.html
    Narsimlu
  • 15979
    Hello Shlomit,
    Please let me know if you need any further assistance with your question.
  • 15979
    Hello Shlomit,
    Thank you for posting on Infragistics forum.
    I have tested your scenario, by adding WebHtmlEditor with fixed size (800x400px) on web page and then exporting all the HTML text from it in one DIV element also with fixed size (800x400px).
    You can see the end result in the screenshots below.
    WebHtmlEditor + DIV on Internet Explorer 8:
    WebHtmlEditor + DIV on Firefox 3.6
    You can see that only the Vertical Scroolbar is active in both WebHtmlEditor and DIV element, when the size of the row is less than size of the control.
    If you can send me some working example, or screenshot representing your scenario I will try to investigate this further.
