I have been trying to freeze (top time-lines header) and the left (resources).
As you can see in the screen attached:
· The column resources on the left gets freezed however, we are not able to control the height of each of the resources so that it’s clearly visible. Can you please let us know how to set the height of the each of the resources?
· Also, if we are successful setting the height of each resources, we will then have to have a vertical scrollbar since there are approximately 50 resources loaded here. In this case, the upper (time-lines header) should get freezed. Not sure if this would be the default behavior. Please let us know?
Please help...
Deven
