590
XamWebGrid Totals
If you see my screen shot below.  I am using SummaryRow, but by default it puts "Sum =".  In my example I customized it, but I really want it to just show the total amount with out any text.  Is there any way do this in XAML?
  • 590
    posted in reply to Elizabeth Albert
    http://forums.infragistics.com/forums/p/37289/216379.aspx
    App.xaml
    <igPrim:SummaryResultFormatStringValueConverter x:Key="SDFormatStringConverter"></igPrim:SummaryResultFormatStringValueConverter>
    <Style TargetType="igPrim:SummaryRowCellControl"  x:Key="CustomSummaryStyle">
            <Setter Property="FontSize" Value="11" />
            <Setter Property="VerticalContentAlignment" Value="Center" />
            <Setter Property="HorizontalContentAlignment" Value="Right"/>
            <Setter Property="Background" Value="{StaticResource SummaryRowBackgroundBrush}"/>
            <Setter Property="BorderBrush" Value="{StaticResource CellItemNormalBorderBrush}"/>
            <Setter Property="BorderThickness" Value="0,0,1,0"/>
            <Setter Property="Padding" Value="7,3"/>
            <Setter Property="SummaryDisplayTemplate">
                <Setter.Value>
                    <DataTemplate>
                        <StackPanel Orientation="Horizontal" HorizontalAlignment="Right">
                            <TextBlock Text="{Binding SummaryDefinition.SummaryOperand.RowDisplayLabel}" />
                            <!--Remove this element-->
                            <!--<TextBlock Text=" = "/>-->
                            <TextBlock Text="{Binding Converter={StaticResource SDFormatStringConverter}}"/>
                        </StackPanel>
                    </DataTemplate>
                </Setter.Value>
            </Setter>
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="igPrim:SummaryRowCellControl">
                        <Grid>
                            <vsm:VisualStateManager.VisualStateGroups>
                                <vsm:VisualStateGroup x:Name="CommonStates">
                                    <vsm:VisualState x:Name="Normal" />
                                    <vsm:VisualState x:Name="MouseOver"/>
                                    <vsm:VisualState x:Name="Alternate" />
                                </vsm:VisualStateGroup>
                                <vsm:VisualStateGroup x:Name="SelectedStates">
                                    <vsm:VisualState x:Name="NotSelected"/>
                                    <vsm:VisualState x:Name="Selected"/>
                                <vsm:VisualStateGroup x:Name="ActiveStates">
                                    <vsm:VisualState x:Name="InActive" />
                                    <vsm:VisualState x:Name="Active">
                                        <Storyboard >
                                            <ObjectAnimationUsingKeyFrames BeginTime="00:00:00" Duration="00:00:00" Storyboard.TargetName="ActiveRect" Storyboard.TargetProperty="(UIElement.Visibility)">
                                                <DiscreteObjectKeyFrame KeyTime="00:00:00" Value="Visible"/>
                                            </ObjectAnimationUsingKeyFrames>
                                        </Storyboard>
                                    </vsm:VisualState>
                                <vsm:VisualStateGroup x:Name="FixedStates">
                                    <vsm:VisualState x:Name="Fixed"/>
                                    <vsm:VisualState x:Name="Unfixed"/>
                            </vsm:VisualStateManager.VisualStateGroups>
                            <Border x:Name="AddNewRowElem" Background="{TemplateBinding Background}" BorderThickness="{TemplateBinding BorderThickness}" BorderBrush="{TemplateBinding BorderBrush}">
                                <Rectangle Height="1" VerticalAlignment="Top" Fill="#7FFFFFFF"/>
                            </Border>
                            <Rectangle Fill="Transparent" Stroke="{StaticResource CellItemSelectedBorderBrush}" StrokeThickness="1" x:Name="ActiveRect" Visibility="Collapsed"></Rectangle>
                            <StackPanel x:Name="SummaryDisplay" HorizontalAlignment="Right" VerticalAlignment="{TemplateBinding VerticalContentAlignment}" Margin="{TemplateBinding Padding}"/>
                        </Grid>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
    UserControl
                        <igGrid:XamWebGrid.SummaryRowSettings>
                            <igGrid:SummaryRowSettings Style="{StaticResource CustomSummaryStyle}"  AllowSummaryRow="Bottom"></igGrid:SummaryRowSettings>
                        </igGrid:XamWebGrid.SummaryRowSettings>
  • 8607
    Hello jbarber2010,
    Please refer to this help topic.  I think that the section at the bottom should be useful.  You can create a SummaryDisplayTemplate and display only the summary amount.
    Let me know if this is not helpful, as I can forward the post to developer support.
    Elizabeth Albert
    Localization Engineer
  • 590
    I found the answer
  • 590
    Verified Answer
    I found the answer to my problem on another post.
