I am trying to build a simple version of XamWebOutlookBar. But it doesnt seem to work. My code mirrors whats in the sample provided other than the data source info.
I am using Infragistics 10.1 and Silverlight 4. Any ideas?
Error Info -
Error HRESULT E_FAIL has been returned from a call to a COM component.
I am using 10.1 and Silverlight 4, so thats probably it. Thanks Stoimen!
Are you using the 10.1 RTM version (have you applied any Service Releases) ?
The RTM version is built against Silverlight 3, so that might be causing your issue.
You either need to build your application for Silverlight 3, or apply our latest SR.
HTH,
