25
How to change the style of marker?
I have a custom style for Marker in a scatterline chart.
How can i change the marker styles based on conditons in the c# file?
  • 1134
    Hi shrutipatra,
    You can change the marker style of your ScatterLine chart in C# by setting the MarkerType on your series to Custom, and then setting the Marker.Style property to the custom style you created.  Here's an example of what I did:
    Here's my custom Marker in my UserControl resources:
    <Style TargetType="igChart:MarkerPointTemplate" x:Name="MarkerStyle">
           <Setter Property="Template">
             <Setter.Value>
                 <ControlTemplate TargetType="igChart:MarkerPointTemplate">
                       <Path Fill="Green" Stretch="Fill" Stroke="Magenta" Data="M157,234 L172.5,190.5 182.5,232.5 147.5,207.5 193.5,205.5 z"/>
         </ControlTemplate>
          </Setter.Value>
       </Setter>
    </Style>
    Here is the code I perform on a button click to set my ScatterLine series marker to my custom marker:
     private void btnSetMarkerStyle_Click(object sender, RoutedEventArgs e)
                Marker m = new Marker();
                m.Type = MarkerType.Custom;
                this.Chart1.Series[0].Marker = m;
                this.Chart1.Series[0].Marker.Style = this.Resources["MarkerStyle"] as Style;
    Hope this helps!
    -Marisa
