540
How to add download button in webgrid?
Hello :
        I want to add a button in webgrid which shows "download" in text field and this column is data bound to database . When user clicks the button  the download dialogue appears for file download.   I adopt  netadvantage 2009 V2. How could I get it?
Daniel
  • 8607
    Hello Daniel,
    This can be done by using the WebGridDocumentExporter or the WebGridExcelExporter (depending on the type of file that should be created for download).  The documentation suggests using a button outside of the grid and putting the export code in the button's click event.  If you want to add the button inside the grid, you could create a template column that holds a button.
    Let me know if you need more information.  I can forward your post to developer support for further assistance.
    Elizabeth Albert
    Localization Engineer
