I'm getting this JavaScript error if I trigger a postback on a page with WebDateTime control inside WebAsyncPanel.
Error: Sys.InvalidOperationException: Two components with the same id 'txtIssueDate' can't be added to the application.
I'm using Infragistics 2010 Vol. 1 controls.
Any ideas?
Ramesh
Hi rtumati,
It has been a while since your post, however in case you stil need assistance I would be glad to help.
You should use an UpdatePanel in conjunction with AJAX controls as a number of issues may occur when putting such controls in a WARP panel. Please refer to the following thread for more information on the subject:
http://blogs.infragistics.com/forums/p/52717/273899.aspx
Please contact me if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
