Say I have a xamGrid with 5 columns and group by turned on for the grid...
Once I group by a column, is there any way to hide that column from the grouped data once the screen is refreshed and the grouping is completed?
I would also like the column to reappear if the same column is removed from the grouping header.
Just to clarify, if I have 5 columns and I group by column 3, I would like to see only columns 1, 2, 4, and 5.
Major K.
That did the trick!
Thanks!
So the xamGrid doesn't currently offer that option.
However, you can achieve this yourself with a little code:
Check out the following forum post:
https://ko.infragistics.com/community/forums/f/retired-products-and-controls/32228/hide-a-grouping-column/175713#175713
Hope this helps,
-SteveZ
