780
change Column's Width
I currently am building a OLAP cube that will be used in a XmlaDataSource. I can see it fine but I've two problems
I need to save the Columns's Width, and after load them From DB.
I need too change, save and load the PivotHeaderCells' Caption.
How can I do it??
  • 27093
    Verified Answer
    Hello ,
    If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
  • 7922
    Verified Answer
    You can read columns width from  ColumnWidth property of DataColumn object.
    this.pivotGrid.DataColumns[0].ColumnWidth
    This property is only with get accessor, but for 11.1 release it will be and settable.
    About PivotHeaderCell caption you can apply new controltemplate to it and can set any type of content in ti.
    Todor
