What is the way to retrieve translations from a cube in SSAS and switch between different languages in a xamPivotGrid?
Hi
You can use code below
XmlaConnectionSettings connSett = new XmlaConnectionSettings(); connSett.DiscoverProperties.Add(new XmlaQueryProperty("key","value")); connSett.ExecuteProperties.Add(new XmlaQueryProperty("key","value")); XmlaDataSource ds = new XmlaDataSource(); ds.ConnectionSettings = connSett;
Todor
Hi Petar,
So how would you accomplish this in code (C#), not xaml?
I have this in my code-behind:
_serverUri = new Uri(this._serverUriAddress, UriKind.Absolute);
this._xmlaDataSource = new XmlaDataSource { ServerUri = _serverUri };
but can't find anything for DiscoverProperties, or ExecuteProperties.
Thanks.
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
To get translations from cube you need to specify locale identifier in connection to the server. Below is example how to do that
<olap:XmlaConnectionSettings x:Key="xmlaSettings" ServerUri="[Specify your server URI here]"> <olap:XmlaConnectionSettings.DiscoverProperties> <olap:XmlaQueryProperty PropertyName="LocaleIdentifier" Value="[Your LCID]"/> </olap:XmlaConnectionSettings.DiscoverProperties> <olap:XmlaConnectionSettings.ExecuteProperties> <olap:XmlaQueryProperty PropertyName="LocaleIdentifier" Value="[Your LCID]"/> </olap:XmlaConnectionSettings.ExecuteProperties></olap:XmlaConnectionSettings>
<olap:XmlaDataSource x:Key="pivotGridDataSource" … ConnectionSettings="{StaticResource xmlaSettings }"></olap:XmlaDataSource>
BTW using the code above you can set any property in connection string that are used for connection to the server Regards Todor
my need is to retrieve from the SSAS the cubes translations of Dimensions names, attributes, measures etc
