760
Chart renders differently with non-zero minimum
I'm seeing the featured measure bar of the graph rendering differently dependant on whether or not I give it a zero minimum. Please refer to the images and xaml below. Thank you in advance!
                                        <ig:XamBulletGraph Height="70" Grid.Column="1"
                                                       MouseEnter="Bullet_MouseEnter"
                                                       MouseLeftButtonDown="Bullet_MouseLeftButtonDown" >
                                        <ig:XamBulletGraph.Scale>
                                            <ig:QuantitativeScale Opacity="{Binding Opacity}" Minimum="{Binding Min}" Maximum="{Binding Max}" Interval="{Binding Increment}">
                                                <ig:QuantitativeScale.Ranges>
                                                    <ig:QualitativeRange Opacity="{Binding Opacity}" Value="{Binding BadToAverageBreakpoint}" Background="#FF5a5a5a"/>
                                                    <ig:QualitativeRange Opacity="{Binding Opacity}" Value="{Binding AverageToGoodBreakpoint}" Background="#FF8d8d8d"/>
                                                </ig:QuantitativeScale.Ranges>
                                                <ig:QuantitativeScale.LabelGroup>
                                                    <ig:BulletGraphLabelGroup Opacity="{Binding Opacity}" StringFormat="{Binding Format}" />
                                                </ig:QuantitativeScale.LabelGroup>
                                            </ig:QuantitativeScale>
                                        </ig:XamBulletGraph.Scale>
                                        <ig:XamBulletGraph.FeaturedMeasures>
                                            <ig:FeaturedMeasure
                                                Value="{Binding Value}"
                                                Background="{Binding BulletColor}"
                                                ToolTipService.ToolTip="{Binding Tooltip}"
                                                Animation="{Binding Path=DataContext.Animation, ElementName=root, Converter={StaticResource BooleanToAnimationConverter}}">
                                                <!--We don't have FindAncestor mode on the RelativeSource markup the way WPF has, so we name the UserControl "root" and reference it as above to get at
                                                a property on the main ViewModel, as opposed to the datacontext of the current child in the ItemsControl.-->
                                            </ig:FeaturedMeasure>
                                        </ig:XamBulletGraph.FeaturedMeasures>
                                        <ig:XamBulletGraph.ComparativeMeasures>
                                            <ig:ComparativeMeasure Value="{Binding Expected}" Opacity="{Binding Opacity}"/>
                                        </ig:XamBulletGraph.ComparativeMeasures>
                                    </ig:XamBulletGraph>
With a non-zero value for minimum:
With a zero for minimum:
  • 17605
    The BulletGraph is working in that way. This is from the BulletGraph specification:
    The Featured Measure
    This portion of the bullet graph displays the primary data and should therefore be visually
    prominent. Usually, it should be encoded as a bar, like the bar on a bar graph. The one
    exception is when the quantitative scale begins at a value greater than zero; in such a case, the
    featured measure should be encoded as a short line perpendicular to the orientation of the
    graph, a dot, or a square.
    More about this:
    http://www.perceptualedge.com/articles/misc/Bullet_Graph_Design_Spec.pdf
