I am using Net Advantage for ASP.NET version 2009 V1. I need to give the pagination for UltraWebGrid which has 4 to 5 fixed columns. After enabling pagination, fixed columns are not displayed, when i nagivate thru the pages after first page. Could some on help me in this regard?
Thanks in advance.
Regards
nrv
Hi nrv,
It has been a while since your post, however in case you still need assistance with the described matter, I would be glad to help.
I have tested your scenario using version 9.1 and 11.1 under Mozilla 7 an IE9 but am so far unable to replicate the issue. I am attaching my sample which uses the Northwind DB and has the CategoryID column set as fixed.
Please contact me if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
