Anyone else run into this? Is Infragistics working on a new release compatibile with IE8?
When running IE8, the Infragistic's popupTool menu items do not expand to show the submenus (buttonTools). We are using the latest release of Infragistics (v8.1 -- build number 8.1.20081.1000) for .Net 2.0.
Did anyone resolve this issue. I now have the same problem.
Neil
it gives the following error when click on the menu:
'lbarObj.Element.style' is null or not an object
ig_weblistbarIE4.js
Code: 0
URI http://servername/ig_common/20062/scripts/ig_weblistbarIE4.js
IE8 is still not officially supported, but in any case, we do appreciate your feedback and will do our best to address the problem. However it is a bit hard for us to understand what is going on without a reproduction first - could you please send us your ASPX menu setup and / or any codebehind related to it and the exxact script error you are getting, so we can investigate further?
I had problem using IE8 with the infragistics dropdown tool bar, it gave me script error. Also, all the stylesheets are not working properly.
Thanks for reporting this problem. We are actually working closely with Microsoft and the IE team to ensure everything we have shipped and will ship will work correctly in IE8. Unfortunately at this point it is a bit early in the IE8 product development lifecycle and there are indeed some generic issues which affect our controls as well. We have reported issues to the IE8 team and actively working on testing our products in IE8.
