540
xamtree item rename
I want to rename the treeitem on right click.
any suggestions
  • 540
    In my xaml I have
            <ControlTemplate x:Name="controlTreeItemTemplate" TargetType="Controls1:XamTreeItem">
                <TextBox x:Name="ModifyText" LostFocus="ModifyTextLostFocus" Loaded="ModifyTextLoaded"></TextBox>
            </ControlTemplate>
    in code behind
            private ControlTemplate _Template;
            // Change the template to a textbox to allow the new report name to be
            // entered directly into the selected tree item.
            private void MenuRenameClick(object sender, EventArgs e)
                //ReportTreeViewModel.MenuRename();
                _Template = _RenameNode.Template;
                _RenameNode = ReportTreeViewModel.SelectedNode;
                _RenameNode.Template = controlTreeItemTemplate;
            // Rename Menu - Default the textbox to the current report name.
            private void ModifyTextLoaded(object sender, RoutedEventArgs e)
                var modifytext = ((TextBox)sender);
                modifytext.Text = _RenameNode.Header.ToString();
                modifytext.Focus();
                modifytext.MaxLength = ReportGroupTreeViewHelper.IsReportNode(_RenameNode) ? 50 : 200;
            // Rename Menu
            private void ModifyTextLostFocus(object sender, RoutedEventArgs e)
               // _RenameNode.Template = null;
                _RenameNode.Template = _Template;
                var tb = (TextBox)sender;
    when I am trying to set template back its throwing error and when I am setting template to null in ModifyTextLostFocus the node is disappearing.
    any help will be appreciated.
