540
XamGrid Item template
 Based on the data type I am pouplating grid's column  with different controls.
All the controls are binded to property on Model
On the Cell Click I am setting SelectedProperty on Model.
The problem is when row with DatePicker is selected and I go and click numericupdown, 1st numericupdown control event is fired and then Grid's Cell Click event is fired . Same is true for DatePicker.
Is there any way to fire 1st Grid's Cell Click or any other event and than NumericUpDown/DatePicker event.
private TemplateColumn _TempCol = new TemplateColumn();
switch (property.SQLDataType.ToLower())
                    case "date":
                            _TempCol.ItemTemplate = Resources["ColDatePicker"] as DataTemplate;
                            break;
                    case "varchar":
                            _TempCol.ItemTemplate = Resources["ColText"] as DataTemplate;
                            break;
                    case "float":
                            _TempCol.ItemTemplate = Resources["ColFloatNumericUpdown"] as DataTemplate;
                            break;
                    case "int":
                            _TempCol.ItemTemplate = Resources["ColIntNumericUpdown"] as DataTemplate;
                            break;
                    case "char":
                            break;
                    case "bit":
                            _TempCol.ItemTemplate = Resources["Colcombobox"] as DataTemplate;
                            break;
