260
can not access the control in Infragistics.DragDrop event
I have implemented drag drop functionality in my silverlight page, inside the event I am trying to access the a page control. I am getting object reference error. but any other silver light page events I am able to access the control...code is here..
private
void DragSource_Drop(object sender, Infragistics.DragDrop.DropEventArgs
e)
DatePicker from = this.FindName("fromDatePicker") as DatePicker
; // here the from is NULL
DatePicker to = this.FindName("toDatePicker") as DatePicker
Border dropTarget = e.DropTarget as Border
Image originalDragSource = e.OriginalDragSource as Image
string
tag = originalDragSource.Tag.ToString();
WeatherContext context = new WeatherContext
context.Load<
RPT_1HOUR
>(context.GetWeatherInfoQuery(from.SelectedDate.Value, to.SelectedDate.Value));
Series series = new Series
series.Label =
"Test Label"
series.ChartType =
ChartType
.Line;
series.DataPointColor =
DataPointColor
.Different;
series.DataMapping =
"Label=DATAPOINT;Value="
+tag;
series.DataSource = context.RPT_1HOURs;
this
.weatherGrid.ItemsSource = context.RPT_1HOURs;
this
.dataChart.Series.Add(series);
Please let me know.
-Sajin
  • 14517
    Hello Sajin,
    I realize it has been some time since your post. I looked at the source code you provided and from this I am unable to determine the issue you are having. Unless the fromDatePicker is inside of some other container this scenario should work.  I have tested this in the attached sample and the behavior was as expected: the fromDatePicker was found. If you still need assistance with this matter, please provide me with more information on the layout of your page.
    Sincerely,
    Valerie
    Developer Support Engineer
    www.infragistics.com/support
    SilverlightApplication1.zip
