hello,
I use NetAdvantage_20073_CLR2X_HotFix_1043 and then work NodeClicked event very often jump out js runtime error. How it correct?
And i have similar errors on all Infragistics control when load site through IIS in ie7, but in FF it work correct.
PS: Sorry for my English.
NightDuty, did you ever get this issue resolved?
Thanks for writing. Could you please tell us a little bit more information about the kind of errors you are getting, for example the exact error message you are getting in IE, or even, if possible, a screenshot of what you see? It is really hard for us to reproduce the problem locally - simply hooking the server side NodeClicked event does not produce javascript errors in any of the scenarios I've tried.
Also, if this is a generic IE7 problem that may appear in all Infragistics controls, then maybe you need to check some security setting - for example if there is some options prohibiting javascript or some kind of security/firewall software installed.
