i am holding selected date value at client side in varibale.
i want that value should be as mm/dd/year.
Please send s code for that .
If you want to store date as string in a global variable, then you need to write conversion/filters for get/setValue member functions. Example:
function checkVal(){ var dc = igdrp_getComboById('WebDateChooser1'); //or //var dc = ig$('WebDateChooser1'); if(!dc) return; //example to convert Date value as string var val = dc.getValue(); if(val) myValueOfWebDC = '' + (val.getMonth() + 1) + '/' + val.getDate() + '/' + val.getFullYear(); else myValueOfWebDC = null; //example to set Date value from your string var date = null; if(myValueOfWebDC) { var fields = myValueOfWebDC.split('/'); date = new Date(); date.setFullYear(parseInt(fields[2])); date.setMonth(parseInt(fields[0]) - 1); date.setDate(parseInt(fields[1])); date.setHours(0); date.setMinutes(0); date.setSeconds(0); date.setMilliseconds(0); } alert("value in WebDC=" + myValueOfWebDC + "\nactual date:" + date); //dc.setValue(date);}
