I'm exporting an UltraWebGrid to Excel using the Excel Exporter. It works great, but now my customer would like to insert the company logo onto the spreadsheet. Is there any way to do this? I've been looking through the docs and forums and haven't seen anything.
Thanks!Scott
Try the SetBoundsInTwips method. It expects parameters in twips which is 1/20th of a point.
wsi.SetBoundsInTwips(ws,
new Rectangle(0, 0, 2000, 2000), true);
SetBoundsInTwips documentation:
https://ko.infragistics.com/help/winforms/infragistics.documents.excel~infragistics.documents.excel.worksheetimage~setboundsintwips(worksheet,rectangle,boolean)
Hope this will help you.
image.TopLeftCornerCell = theWorkSheet1.Rows[0].Cells[0];
image.BottomRightCornerCell = theWorkSheet1.Rows[4].Cells[1];
theWorkSheet1.Shapes.Add(image);
Can you please help me, how to fix the width and height of image within excel ?. I am trying to use the property 'ws.image.size.width' provided by infragistics. I get an error saying Expression is a value and therefore cannot be the target of an assignment. It will be great if i get an reply regarding this. Thanks.
devip said: Have you got the answer? Please share with us if you have. I user 2006 V3 and has to export the images to excel. Please let me knwo if it is possible.
Unfortunately, we did not find a solution within the time constraints of the project. Instead, we used Crystal to generate a PDF with the exact formatting the client wanted. In this case, they decided they could do without being able to manipulate the data in Excel.
